nzbdrone is crashing when trying to manually search for an episode. I have tested this with several shows and they all seem to be giving the same issue. I’m seeing the following error in the log file:
14-9-22 20:51:41.9|Debug|Parser|Episode Parsed. castle2009 - S05E24
14-9-22 20:51:41.9|Debug|Parser|Language parsed: English
14-9-22 20:51:41.9|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Castle.2009.S05E24.720p.HDTV.X264-DIMENSION
14-9-22 20:51:41.9|Debug|Parser|Quality parsed: HDTV-720p v1
14-9-22 20:51:41.9|Debug|Parser|Release Group parsed: DIMENSION
14-9-22 20:51:41.9|Debug|AcceptableSizeSpecification|Beginning size check for: Castle.2009.S05E24.720p.HDTV.X264-DIMENSION
14-9-22 20:51:41.9|Debug|AcceptableSizeSpecification|Item: Castle.2009.S05E24.720p.HDTV.X264-DIMENSION, meets size constraints.
14-9-22 20:51:41.9|Trace|ConfigService|Unable to find config key ‘enablefaileddownloadhandling’ defaultValue:‘True’
14-9-22 20:51:41.9|Debug|LanguageSpecification|Checking if report meets language requirements. English
14-9-22 20:51:41.9|Debug|NotRestrictedReleaseSpecification|Checking if release contains any restricted terms: Castle.2009.S05E24.720p.HDTV.X264-DIMENSION
14-9-22 20:51:41.9|Trace|ConfigService|Unable to find config key ‘releaserestrictions’ defaultValue:’‘
14-9-22 20:51:41.9|Debug|NotRestrictedReleaseSpecification|No restrictions configured, allowing: Castle.2009.S05E24.720p.HDTV.X264-DIMENSION
14-9-22 20:51:41.9|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. HDTV-720p v1
14-9-22 20:51:41.9|Debug|QualityAllowedByProfileSpecification|Quality HDTV-720p v1 rejected by Series’ quality profile
14-9-22 20:51:41.9|Trace|ConfigService|Unable to find config key ‘retention’ defaultValue:'0’
14-9-22 20:51:41.9|Debug|RetentionSpecification|Checking if report meets retention requirements. 497
14-9-22 20:51:41.9|Trace|ConfigService|Unable to find config key ‘enablefaileddownloadhandling’ defaultValue:'True’
14-9-22 20:51:41.9|Trace|ConfigService|Unable to find config key ‘blacklistretrylimit’ defaultValue:'1’
14-9-22 20:51:41.9|Debug|DelaySpecification|Ignore delay for searches
14-9-22 20:51:41.9|Debug|HistorySpecification|Skipping history check during search
14-9-22 20:51:41.9|Debug|MonitoredEpisodeSpecification|Skipping monitored check during search
14-9-22 20:51:41.9|Debug|SeriesSpecification|Checking if series matches searched series
14-9-22 20:51:41.9|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Quality rejected by series profile
14-9-22 20:51:45.8|Trace|Scheduler|Pending Tasks: 1
14-9-22 20:51:45.8|Trace|CommandExecutor|Publishing TrackedCommandCleanupCommand
14-9-22 20:51:45.8|Trace|CommandExecutor|TrackedCommandCleanupCommand -> CommandTrackingService
14-9-22 20:51:45.8|Trace|EventAggregator|Publishing CommandExecutedEvent
14-9-22 20:51:45.8|Trace|EventAggregator|CommandExecutedEvent -> TaskManager
14-9-22 20:51:45.8|Trace|TaskManager|Updating last run time for: NzbDrone.Core.Messaging.Commands.Tracking.TrackedCommandCleanupCommand
14-9-22 20:51:45.9|Trace|EventAggregator|CommandExecutedEvent <- TaskManager
14-9-22 20:51:45.9|Trace|EventAggregator|CommandExecutedEvent -> TaskModule
14-9-22 20:51:45.9|Trace|EventAggregator|CommandExecutedEvent <- TaskModule
14-9-22 20:51:45.9|Trace|CommandExecutor|TrackedCommandCleanupCommand <- CommandTrackingService [00:00:00]
14-9-22 20:51:48.9|Trace|NzbDroneErrorPipeline|Handling Exception
14-9-22 20:51:48.9|Fatal|NzbDroneErrorPipeline|Request Failed
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.MissingMethodException: No parameterless constructor defined for this object.
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at Nancy.Json.JavaScriptSerializer.ConvertToObject(IDictionary2 dict, Type type) at Nancy.Json.JavaScriptSerializer.ConvertToType(Type type, Object obj) at Nancy.Json.JavaScriptSerializer.ConvertToObject(IDictionary
2 dict, Type type)
at Nancy.Json.JavaScriptSerializer.ConvertToObject(IDictionary2 dict, Type type) at Nancy.Json.JavaScriptSerializer.ConvertToType(Type type, Object obj) at Nancy.Json.JavaScriptSerializer.ConvertToType[T](Object obj) at Nancy.Json.JavaScriptSerializer.Deserialize[T](String input) --- End of inner exception stack trace --- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at Nancy.ModelBinding.DefaultBodyDeserializers.JsonBodyDeserializer.Deserialize(String contentType, Stream bodyStream, BindingContext context) at Nancy.ModelBinding.DefaultBinder.DeserializeRequestBody(BindingContext context) at Nancy.ModelBinding.DefaultBinder.Bind(NancyContext context, Type modelType, Object instance, BindingConfig configuration, String[] blackList) at Nancy.ModelBinding.DynamicModelBinderAdapter.TryConvert(ConvertBinder binder, Object& result) at CallSite.Target(Closure , CallSite , Object ) at Nancy.ModelBinding.ModuleExtensions.Bind[TModel](INancyModule module) at NzbDrone.Api.Indexers.ReleaseModule.<.ctor>b__0(Object x) in m:\BuildAgent2\work\328d72309b633a8\src\NzbDrone.Api\Indexers\ReleaseModule.cs:line 47 at CallSite.Target(Closure , CallSite , Func
2 , Object )
at Nancy.Routing.Route.<>c__DisplayClass4.b__3(Object parameters, CancellationToken context)
14-9-22 20:51:54.2|Trace|EventAggregator|Publishing UpdateQueueEvent
14-9-22 20:51:54.2|Trace|EventAggregator|UpdateQueueEvent -> QueueModule
14-9-22 20:51:54.2|Trace|EventAggregator|UpdateQueueEvent <- QueueModule
