Sonarr version (exact version): v3.0.0.348
Mono version (if Sonarr is not running on Windows): 5.18.0.225
OS: lsiodev/sonarr-preview
Debug logs: https://pastebin.com/Xww8VxDq
When Sonarr is running the 12 hour refresh it start getting timeouts when connecting to https://skyhook.sonarr.tv/ and when it gets one all the following will also timeout, I can do a curl from the docker container as the messages shows up in the log and to the failed url and it works, also if I restart the sonarr everything starts working again until it hits its first timeout
You didn’t see this behaviour with v2 at all? There isn’t a significant difference between the two in this regard.
No I have not, I will try to rebuild if there has been no major code changes then it has to be my install
