Sonarr version (exact version): 2.0.0.4230
Mono version (if Sonarr is not running on Windows):4.2.3 (Stable 4.2.3.4/832de4b
OS: Unraid docker
((Debug logs)): Don’t think needed will if told otherwise
Description of issue: Hi, wanting to set me naming scheme to show release group at the end with [brackets] it’s fine on tv shows and anime, but anime multi episode comes up as Invalid format.
Which format are you trying to use?
Invalid format means Sonarr can’t parse it properly so it would be unable to import files named that way.
I hope this helps.
As you can see it has no problem with single episodes, only the multi episode it says it’s no good
The issue is with the release group at the end in square brackets and it containing the season + episode numbers as well as absolute episode numbers. We should have a fix for this in the next release.
