Error occurred refreshing series info
Mono version (if Sonarr is not running on Windows): 5.8.0.108-11
OS: DSM 6.1.5-15254 Update 1
Debug logs: https://pastebin.com/igwybAR6
I having issues refreshing some series.
i have this error
Error occurred while executing task RefreshSeries: Failed to read complete http response
this happen with some series, like The Flash or The walking Dead. Other seem to be fine.
thanks and sorry for my english.
adding some info…
I can not add new series either.
Looks like issues connecting through CloudFlare. If you look at the debug logs you can get the URL and see if that loads from another system on your network.
Hello Markus. Thanks for your reply.
Im looking for some url in this debug log, but i can not find some… :frowning:
Can you give me some clue where the url should be?
thanks in advance.
Trace level logs.
Thanks Taloth.
Im have tried adding a new serie and i can see 2 url´s.
http://skyhook.sonarr.tv/v1/tvdb/search/en/?term=the%20walking%20dead
this is what i see in a broswer
and http://skyhook.sonarr.tv/v1/tvdb/shows/en/153021
with this result
i tried in chrome and edge.
and this is the error i have in trace log.
I hope it will be useful
thanks and -again- sorry for my english.
Could someone figure out what is happening here?
