System.NotSupportedException: The given path’s format is not supported.
at System.Security.Permissions.FileIOPermission.QuickDemand(FileIOPermissionAccess access, String fullPath, Boolean checkForDuplicates, Boolean needFullPath)
at System.IO.FileInfo.Init(String fileName, Boolean checkHost)
at System.IO.FileInfo…ctor(String fileName)
at NzbDrone.Common.Extensions.PathExtensions.CleanFilePath(String path) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Extensions\PathExtensions.cs:line 30
at NzbDrone.Common.PathEqualityComparer.GetHashCode(String obj) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\PathEqualityComparer.cs:line 26
at System.Linq.Set1.InternalGetHashCode(TElement value) at System.Linq.Set1.Find(TElement value, Boolean add)
at System.Linq.Enumerable.d__721.MoveNext() at System.Collections.Generic.List1…ctor(IEnumerable1 collection) at System.Linq.Enumerable.ToList[TSource](IEnumerable1 source)
at NzbDrone.Core.Metadata.Files.MetadataFileService.FilterExistingFiles(List`1 files, Series series) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Metadata\Files\MetadataFileService.cs:line 67
at NzbDrone.Core.Metadata.ExistingMetadataService.Handle(SeriesScannedEvent message) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Metadata\ExistingMetadataService.cs:line 47
at NzbDrone.Core.Messaging.Events.EventAggregator.PublishEvent[TEvent](TEvent event) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Messaging\Events\EventAggregator.cs:line 56
And:
MetadataService failed while processing [MediaCoversUpdatedEvent]: Sequence contains no elements
System.InvalidOperationException: Sequence contains no elements
at System.Linq.Enumerable.First[TSource](IEnumerable1 source) at NzbDrone.Core.Metadata.Consumers.Roksbox.RoksboxMetadata.EpisodeImages(Series series, EpisodeFile episodeFile) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Metadata\Consumers\Roksbox\RoksboxMetadata.cs:line 245 at NzbDrone.Core.Metadata.MetadataService.ProcessEpisodeImages(IMetadata consumer, Series series, EpisodeFile episodeFile, List1 existingMetadataFiles) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Metadata\MetadataService.cs:line 328
at NzbDrone.Core.Metadata.MetadataService.Handle(MediaCoversUpdatedEvent message) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Metadata\MetadataService.cs:line 64
at NzbDrone.Core.Messaging.Events.EventAggregator.PublishEvent[TEvent](TEvent event) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Messaging\Events\EventAggregator.cs:line 566
The only think I have in my DEBUG logs from today are the following:
16-6-1 12:55:31.2|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\nzbdrone.console.exe - Version 2.0.0.4163
16-6-1 12:55:31.6|Debug|ServiceProvider|Checking if service NzbDrone exists.
16-6-1 15:44:29.9|Info|Bootstrap|Starting Sonarr - C:\ProgramData\NzbDrone\bin\nzbdrone.console.exe - Version 2.0.0.4163
16-6-1 15:44:30.2|Debug|ServiceProvider|Checking if service NzbDrone exists.
In that case enable debug logging now and refresh the series, which should throw the same error again, if it hasn’t been resolved automatically by background cleaning.
[v2.0.0.4163] System.NotSupportedException: The given path’s format is not supported.
16-6-1 19:47:31.7|Debug|CleanMetadataService|Cleaning missing metadata files for series: Portlandia
16-6-1 19:47:31.8|Debug|MediaBrowserMetadata|Generating series.xml for: Portlandia
16-6-1 19:47:31.8|Debug|MediaBrowserMetadata|Saving series.xml for Portlandia
16-6-1 19:47:31.8|Debug|MetadataService|Series image already exists: \wdmycloud\nfs\TV\Portlandia\Portlandia.jpg
16-6-1 19:47:31.8|Debug|RoksboxMetadata|Failed to parse season number from \wdmycloud\nfs\TV\Portlandia\Specials for series Portlandia.
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Failed to parse season number from \wdmycloud\nfs\TV\Portlandia\Specials for series Portlandia.
16-6-1 19:47:31.9|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\Season 06\Season 06.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E05 - Breaking Up WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E05 - Breaking Up WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E04 - Weirdo Beach WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E04 - Weirdo Beach WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E03 - Shville WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E03 - Shville WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E02 - Going Gray WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E02 - Going Gray WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E01 - Pickathon WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E01 - Pickathon WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Specials\Portlandia - S00E02 - The Brunch Special HDTV-720p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Specials\Portlandia - S00E02 - The Brunch Special HDTV-720p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E06 - TADA WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E06 - TADA WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E07 - Family Emergency WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E07 - Family Emergency WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E08 - First Feminist City WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E08 - First Feminist City WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E09 - Lance Is Smart WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E09 - Lance Is Smart WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|RoksboxMetadata|Generating Episode Metadata for: Season 06\Portlandia - S06E10 - Noodle Monster WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E10 - Noodle Monster WEBDL-1080p.jpg
16-6-1 19:47:31.9|Debug|MetadataService|Series image already exists: \wdmycloud\nfs\TV\Portlandia\folder.jpg
16-6-1 19:47:31.9|Info|RefreshEpisodeService|Starting episode info refresh for: [277165][Silicon Valley]
16-6-1 19:47:31.9|Debug|WdtvMetadata|Failed to parse season number from \wdmycloud\nfs\TV\Portlandia\Specials for series Portlandia.
16-6-1 19:47:31.9|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\Season 06\folder.jpg
16-6-1 19:47:31.9|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E05 - Breaking Up WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E05 - Breaking Up WEBDL-1080p.metathumb
16-6-1 19:47:31.9|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E04 - Weirdo Beach WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E04 - Weirdo Beach WEBDL-1080p.metathumb
16-6-1 19:47:31.9|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E03 - Shville WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E03 - Shville WEBDL-1080p.metathumb
16-6-1 19:47:31.9|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E02 - Going Gray WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E02 - Going Gray WEBDL-1080p.metathumb
16-6-1 19:47:31.9|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E01 - Pickathon WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E01 - Pickathon WEBDL-1080p.metathumb
16-6-1 19:47:31.9|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Specials\Portlandia - S00E02 - The Brunch Special HDTV-720p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Specials\Portlandia - S00E02 - The Brunch Special HDTV-720p.metathumb
16-6-1 19:47:31.9|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E06 - TADA WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E06 - TADA WEBDL-1080p.metathumb
16-6-1 19:47:31.9|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E07 - Family Emergency WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E07 - Family Emergency WEBDL-1080p.metathumb
16-6-1 19:47:31.9|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E08 - First Feminist City WEBDL-1080p.mkv
16-6-1 19:47:31.9|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E08 - First Feminist City WEBDL-1080p.metathumb
16-6-1 19:47:32.0|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E09 - Lance Is Smart WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E09 - Lance Is Smart WEBDL-1080p.metathumb
16-6-1 19:47:32.0|Debug|WdtvMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E10 - Noodle Monster WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E10 - Noodle Monster WEBDL-1080p.metathumb
16-6-1 19:47:31.9|Debug|EpisodeAddedService|No new episodes, skipping search
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating tvshow.nfo for: Portlandia
16-6-1 19:47:32.0|Info|RefreshEpisodeService|Finished episode refresh for series: [277165][Silicon Valley].
16-6-1 19:47:32.0|Debug|XbmcMetadata|Saving tvshow.nfo for Portlandia
16-6-1 19:47:32.0|Debug|RefreshSeriesService|Finished series refresh for Silicon Valley
16-6-1 19:47:32.0|Debug|MetadataService|Series image already exists: \wdmycloud\nfs\TV\Portlandia\fanart.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Series image already exists: \wdmycloud\nfs\TV\Portlandia\banner.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Series image already exists: \wdmycloud\nfs\TV\Portlandia\poster.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season-specials-poster.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season01-poster.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season01-banner.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season02-poster.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season02-banner.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season03-poster.jpg
16-6-1 19:47:32.0|Info|DiskScanService|Scanning disk for Silicon Valley
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season03-banner.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season04-poster.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season04-banner.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season05-poster.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season05-banner.jpg
16-6-1 19:47:32.0|Debug|MetadataService|Season image already exists: \wdmycloud\nfs\TV\Portlandia\season06-poster.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E05 - Breaking Up WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E05 - Breaking Up WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E04 - Weirdo Beach WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E04 - Weirdo Beach WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E03 - Shville WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E03 - Shville WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E02 - Going Gray WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E02 - Going Gray WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E01 - Pickathon WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E01 - Pickathon WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Specials\Portlandia - S00E02 - The Brunch Special HDTV-720p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Specials\Portlandia - S00E02 - The Brunch Special HDTV-720p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E06 - TADA WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E06 - TADA WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E07 - Family Emergency WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E07 - Family Emergency WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E08 - First Feminist City WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E08 - First Feminist City WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E09 - Lance Is Smart WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E09 - Lance Is Smart WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.0|Debug|XbmcMetadata|Generating Episode Metadata for: \wdmycloud\nfs\TV\Portlandia\Season 06\Portlandia - S06E10 - Noodle Monster WEBDL-1080p.mkv
16-6-1 19:47:32.0|Debug|MetadataService|Episode image already exists: Season 06\Portlandia - S06E10 - Noodle Monster WEBDL-1080p-thumb.jpg
16-6-1 19:47:32.1|Debug|DiskScanService|Scanning ‘\wdmycloud\nfs\TV\Silicon Valley’ for video files
16-6-1 19:47:32.4|Debug|DiskScanService|9 video files were found in \wdmycloud\nfs\TV\Silicon Valley
16-6-1 19:47:32.4|Debug|DiskScanService|[277165][Silicon Valley] Cleaning up media files in DB
16-6-1 19:47:32.4|Debug|ImportDecisionMaker|Analyzing 0/9 files.
16-6-1 19:47:32.4|Info|DiskScanService|Completed scanning disk for Silicon Valley
Yeah, I’ve seen this before, and there is nothing before it:
16-5-28 01:00:02.2|Info|RefreshSeriesService|Updating Info for The Walking Dead
16-5-28 01:00:02.7|Info|RefreshEpisodeService|Starting episode info refresh for: [153021][The Walking Dead]
16-5-28 01:00:02.8|Info|RefreshEpisodeService|Finished episode refresh for series: [153021][The Walking Dead].
16-5-28 01:00:02.8|Info|DiskScanService|Scanning disk for The Walking Dead
16-5-28 01:00:06.7|Info|DiskScanService|Completed scanning disk for The Walking Dead
16-5-28 01:00:06.7|Error|EventAggregator|ExistingMetadataService failed while processing [SeriesScannedEvent]
Can you enable ((trace logging)), clear your log files then refresh The Walking Dead and post the contents to hastebin.com that should give us all the details we can get.
Yeah, that was it, still not exactly what I was hoping for (not your fault). Would you be able to make a ((backup)) of your database and PM me a link to download it (Dropbox or google drive are good places to put it)? I want to do some digging in the database and find out why its getting tripped up.
