When setting up it passes the test but when something tries to download I get this error.
Request Failed: Unable to connect to NZBVortex, please check your settings
Exception
NzbDrone.Core.Download.Clients.DownloadClientException: Unable to connect to NZBVortex, please check your settings —> System.Net.WebException: The request timed out
at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) [0x00065] in /private/tmp/source-mono-mac-4.0.0-bug-33585-hotfix/bockbuild-mono-4.0.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.0.4/mcs/class/System/System.Net/HttpWebRequest.cs:946
at System.Net.HttpWebRequest.GetResponse () [0x0000e] in /private/tmp/source-mono-mac-4.0.0-bug-33585-hotfix/bockbuild-mono-4.0.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.0.4/mcs/class/System/System.Net/HttpWebRequest.cs:958
at RestSharp.Http.GetRawResponse (System.Net.HttpWebRequest request) [0x00000] in :0
at NzbDrone.Core.Download.Clients.NzbVortex.NzbVortexProxy.CheckForError (RestSharp.IRestResponse) [0x00054] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\NzbVortex\NzbVortexProxy.cs:233
at NzbDrone.Core.Download.Clients.NzbVortex.NzbVortexProxy.ProcessRequest (RestSharp.IRestClient,RestSharp.IRestRequest) [0x0003a] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\NzbVortex\NzbVortexProxy.cs:207
at NzbDrone.Core.Download.Clients.NzbVortex.NzbVortexProxy.ProcessRequest (RestSharp.IRestRequest,NzbDrone.Core.Download.Clients.NzbVortex.NzbVortexSettings) [0x00008] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\NzbVortex\NzbVortexProxy.cs:190
at NzbDrone.Core.Download.Clients.NzbVortex.NzbVortexProxy.ProcessRequest<NzbDrone.Core.Download.Clients.NzbVortex.Responses.NzbVortexAddResponse> (RestSharp.IRestRequest,NzbDrone.Core.Download.Clients.NzbVortex.NzbVortexSettings) <0x00023>
at NzbDrone.Core.Download.Clients.NzbVortex.NzbVortexProxy.DownloadNzb (byte,string,int,NzbDrone.Core.Download.Clients.NzbVortex.NzbVortexSettings) [0x00057] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\NzbVortex\NzbVortexProxy.cs:50
at NzbDrone.Core.Download.Clients.NzbVortex.NzbVortex.AddFromNzbFile (NzbDrone.Core.Parser.Model.RemoteEpisode,string,byte) [0x00021] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\NzbVortex\NzbVortex.cs:36
at NzbDrone.Core.Download.UsenetClientBase1<NzbDrone.Core.Download.Clients.NzbVortex.NzbVortexSettings>.Download (NzbDrone.Core.Parser.Model.RemoteEpisode) <0x00377> at NzbDrone.Core.Download.DownloadService.DownloadReport (NzbDrone.Core.Parser.Model.RemoteEpisode) [0x00166] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\DownloadService.cs:66 at NzbDrone.Api.Queue.QueueActionModule.Grab () [0x0002d] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\Queue\QueueActionModule.cs:108 at NzbDrone.Api.Queue.QueueActionModule.<.ctor>b__5 (object) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\Queue\QueueActionModule.cs:41 at (wrapper dynamic-method) object.CallSite.Target (System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func
2<object, object>,object) <IL 0x00038, 0x00086>
at Nancy.Routing.Route/<>c__DisplayClass4.b__3 (object,System.Threading.CancellationToken) <IL 0x0005f, 0x0013b>
Version
2.0.0.3718
Mono Version
4.0.4 ((detached/d481017 Mon Sep 28 17:32:19 EDT 2015)
AppData directory
/Users/xxxxx/.config/NzbDrone
Startup directory
/Applications/Sonarr.app/Contents/MacOS
NZBVortex Version 3.2.3 (3.2.3)
