Hello everyone.
I have a problem trying to add the indexer KAT and omgwtfnzbs, my configuration is a Mac Mini end 2009 with OSX 10.11 and last version of sonar.
This is the log:
omgwtfnzbs
Message
Unable to connect to indexer: Curl Error SslCaCert for Url https://rss.omgwtfnzbs.org/rss-download.php?catid=19,20&user=*******&api=<removed>&eng=1&delay=30: Curl Error SslCaCert for Url https://rss.omgwtfnzbs.org/rss-download.php?catid=19,20&user=*********&api=**************************************&eng=1&delay=30
Exception
System.Net.WebException: Curl Error SslCaCert for Url https://rss.omgwtfnzbs.org/rss-download.php?catid=19,20&user=********&api=**********************&eng=1&delay=30
at NzbDrone.Common.Http.CurlHttpClient.GetResponse (NzbDrone.Common.Http.HttpRequest httpRequest, System.Net.HttpWebRequest webRequest) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\CurlHttpClient.cs:line 90
at NzbDrone.Common.Http.HttpClient.ExecuteCurlRequest (NzbDrone.Common.Http.HttpRequest request, System.Net.HttpWebRequest webRequest) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:line 193
at NzbDrone.Common.Http.HttpClient.ExecuteRequest (NzbDrone.Common.Http.HttpRequest request, System.Net.HttpWebRequest webRequest) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:line 180
at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:line 78
at NzbDrone.Core.Indexers.HttpIndexerBase`1[TSettings].FetchIndexerResponse (NzbDrone.Core.Indexers.IndexerRequest request) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 209
at NzbDrone.Core.Indexers.HttpIndexerBase`1[TSettings].FetchPage (NzbDrone.Core.Indexers.IndexerRequest request, IParseIndexerResponse parser) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 195
at NzbDrone.Core.Indexers.HttpIndexerBase`1[TSettings].TestConnection () in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:line 223
KAT
Message
Unable to connect to indexer: The request timed out: The request timed out
Exception
System.Net.WebException: The request timed out
at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) in /private/tmp/source-mono-mac-4.2.0-branch/bockbuild-mono-4.2.0-pre2-branch/profiles/mono-mac-xamarin/build-root/mono-4.2.0/mcs/class/System/System.Net/HttpWebRequest.cs:line 946
at System.Net.HttpWebRequest.GetResponse () in /private/tmp/source-mono-mac-4.2.0-branch/bockbuild-mono-4.2.0-pre2-branch/profiles/mono-mac-xamarin/build-root/mono-4.2.0/mcs/class/System/System.Net/HttpWebRequest.cs:line 958
at NzbDrone.Common.Http.HttpClient.ExecuteWebRequest (NzbDrone.Common.Http.HttpRequest request, System.Net.HttpWebRequest webRequest) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\HttpClient.cs:line 213
Can anyone help me to solve this problem?
Thanks at all.
