This just started happening recently after having used Sonarr/Drone for over a year without issue. Near as I can tell, it’s downloading WEB-DL nzbs, but then when they finished they get moved and renamed as only HDTV, which is lower on my quality profile so it goes back for a WEB-DL (often the same one) which it redownloads then again gets named as HDTV. Repeat ad naseum. Here’s an example chunk of what I hope is the correct log:
15-2-13 07:01:26.4|Info|DownloadService|Report sent to download client. Its.Always.Sunny.in.Philadelphia.S10E05.The.Gang.Spies.Like.U.S.720p.WEB-DL.AAC2.0.H.264-Oosh-NZBgeek
15-2-13 07:01:26.8|Info|RssSyncService|RSS Sync Completed. Reports found: 500, Reports grabbed: 1
15-2-13 07:04:57.9|Info|RecycleBinProvider|Recycling Bin has not been configured, deleting permanently. E:\TV Shows\It's Always Sunny in Philadelphia\Season 10\It's Always Sunny in Philadelphia - S10E05 - The Gang Spies Like U.S HDTV-720p.mkv
15-2-13 07:16:32.1|Info|RssSyncService|Starting RSS Sync
15-2-13 07:16:44.7|Info|DownloadDecisionMaker|Processing 500 reports
15-2-13 07:16:48.8|Info|Sabnzbd|Adding report [Its.Always.Sunny.in.Philadelphia.S10E05.The.Gang.Spies.Like.U.S.720p.WEB-DL.AAC2.0.H.264-Oosh-NZBgeek] to the queue.
15-2-13 07:16:49.5|Info|DownloadService|Report sent to download client. Its.Always.Sunny.in.Philadelphia.S10E05.The.Gang.Spies.Like.U.S.720p.WEB-DL.AAC2.0.H.264-Oosh-NZBgeek
15-2-13 07:16:49.7|Info|RssSyncService|RSS Sync Completed. Reports found: 500, Reports grabbed: 1
15-2-13 07:20:21.1|Info|RecycleBinProvider|Recycling Bin has not been configured, deleting permanently. E:\TV Shows\It's Always Sunny in Philadelphia\Season 10\It's Always Sunny in Philadelphia - S10E05 - The Gang Spies Like U.S HDTV-720p.mkv
15-2-13 07:31:56.4|Info|RssSyncService|Starting RSS Sync
15-2-13 07:32:00.4|Info|DownloadDecisionMaker|Processing 500 reports
15-2-13 07:32:06.4|Info|Sabnzbd|Adding report [Its.Always.Sunny.in.Philadelphia.S10E05.The.Gang.Spies.Like.U.S.720p.WEB-DL.AAC2.0.H.264-Oosh-NZBgeek] to the queue.
15-2-13 07:32:07.2|Info|DownloadService|Report sent to download client. Its.Always.Sunny.in.Philadelphia.S10E05.The.Gang.Spies.Like.U.S.720p.WEB-DL.AAC2.0.H.264-Oosh-NZBgeek
15-2-13 07:32:07.4|Info|RssSyncService|RSS Sync Completed. Reports found: 500, Reports grabbed: 1
15-2-13 07:35:38.8|Info|RecycleBinProvider|Recycling Bin has not been configured, deleting permanently. E:\TV Shows\It's Always Sunny in Philadelphia\Season 10\It's Always Sunny in Philadelphia - S10E05 - The Gang Spies Like U.S HDTV-720p.mkv
15-2-13 07:47:14.8|Info|RssSyncService|Starting RSS Sync
15-2-13 07:47:18.3|Info|DownloadDecisionMaker|Processing 500 reports
15-2-13 07:47:25.2|Info|Sabnzbd|Adding report [Its.Always.Sunny.in.Philadelphia.S10E05.The.Gang.Spies.Like.U.S.720p.WEB-DL.AAC2.0.H.264-Oosh-NZBgeek] to the queue.
I hope I’m submitting this right… Let me know if you need anything else, or different logs, or whatnot.
