Episodes not being grabbed
I’m having this same problem actually but it doesn’t have to do with connecting to a WiFi network. I’m running NZBdrone off a hardwired Win 7 server.
It happened to me first last week when downloading the first episode of South Park. I have some of my shows set to only download WEB-DL files (prefer the quality and don’t mind waiting). Anyway, after a few days, nothing had downloaded so I checked manually for a file. There ended up being a couple of WEB-DL releases posted days ago. I thought it was odd but manually grabbed it and it downloaded fine.
Today I check and see that New Girl hadn’t downloaded either. I manually searched again and saw that a WEB-DL was also posted - same for Brooklyn Nine Nine.
Any ideas on how to fix this? I did a manual RSS Sync and neither shows were pulled.
Moved to a new thread because the other one was solved.
You mentioned it was the same issue, but does your system running drone go to sleep?
Manual search in drone? or on the indexer?
Please provide debug logs, manually running the RSS Sync will only work if those episodes were actually on the indexers RSS feed still (last 100 items). Please see http://forums.nzbdrone.com/t/about-the-help-support-category/9 for the info we need. Also a manual search will show you why each release was skipped.
This is actually quite different from what I had going here. In my case manual RSS sync did find the shows, I didn’t have to go as far as manual searches.
Anyway, I suggest you follow markus101’s instructions and hope your problem is solved soon!
