Episodes not actually being renamed
I have all my folders imported, in this example I’ll use “Marvel’s Agents of S.H.I.E.L.D”, the last 2 weeks (since I reinstalled) the episodes have been downloaded and named “Marvel’s Agents of S.H.I.E.L.D - #x##” no episode title. And yesterday I noticed my history said that the file had been downloaded but the series view said it hadn’t. Turns out the episode is named “Marvels Agents of S H I E L D - #x##”, exactly like the file that was downloaded (minus the quality/group/proper stuff) and that created a new folder named “Marvels Agents of S H I E L D”. I have the episode management set to “{Series Title} - {season}x{episode:00} - {Episode Title}” but it’s not actually renaming any of my downloads.
I’d like NZBDrone to use theTVDB since I have Plex and XBMC on multiple systems, but if it can’t, is there a way to trigger a batch file to run theRenamer?
Sounds like these two topics might help you solve your issue, the first would be a naming issue, but it would only affect a couple shows, if none of them are importing then its not a naming issue and the 2nd link will explain how to setup sorting with your download client and drone.
And I found the problem, a script that was marked disabled in NZBGet was still doing post things via a rogue process (service). I was tipped off when I went to reload both programs and files were still being moved around. Thanks for breaking it down.
