I have an entire season of persons of interest already in my library and have woken up to the entire season having downloaded again over night using heaps of my quota. Does anyone know why this would occur? Download proper is also turned off.
The quality on disk didn’t match the cutoff, then the episodes were reposted, so they were grabbed again. You will need to change your cutoff for the profile of that series or unmonitor the older episodes: https://github.com/NzbDrone/NzbDrone/wiki/Monitoring-Series-and-Episodes
Thanks! Im still working out the quality profile thing as even though I have some set to 720 i get messages saying they dont meet the quality profile
that perhaps has something to do with the “Quality Definitions” just perhaps check those out as well and make sure they are set so the episodes fall within the sizes set for example if you have a 720p defination set so the minimum size is 1.20gb and a max of say 2gb if the file is either less than 1.20gb or larger than 2gb then that may be what restricts the episode because it is either too small or too large to meet what you set
