Sonarr version (exact version): 2.0.0.5270
OS: Windows
Description of issue: Episodes for Season 5 of Empire (2015) are not listed so Sonarr is not looking for them. The only episode listed is episode 1 and that is the only episode that sonarr downloaded. I’m having to manually download the files and even if I select the proper label I will still have to manually move the files to the proper folder. Sonarr Will not pick them up, rename them, nor move them. I hope this issue will be fixed soon. Thanks for your hard work…
Are they listed on tvdb ?
I’m on my phone and at work so I can check myself.
I just checked…they’re on TVDB
Is your system 24/7 on for updates ?
Yes always
Could you do a manual search and add a link to a full debug log.
Then we can ask @markus101 to take a look.
I have no idea how to do that
