I have set the sliders on the HDTV-720p profile to the following settings:
Minimum for 30 minute episode: 597.00 MB
Minimum for 60 minute episode: 1.17 GB
Maximum for 30 minute episode: 1.13 GB
Maximum for 60 minute episode: 2.25 GB
This has been working well on newsgroups.
I have just hooked up a torrent client and had done an automatic search for some epps of Marvel’s Jessica Jones. These epps have a 60 min run time on TheTVDB.
Yet a number of the torrents automatically queued up were anywhere from 110 MB to 440 MB.
There where 8 epps in this size range automatically queued.
The Series has been given the HD-720p profile when it was added, and the profile has had the above min/max limits the whole time.
How is it that these epps of smaller sizes have been automatically queued up and how can I fix this?
Actually… I may have just worked this out. Under the HD-720p profile I had Bluray-720p and WEBDL-720p and HDTV-720p checked in the Qualities section… but I had not set the sliders for these.
I did have HDTV-720p set as the Cutoff though and that is the one I did have the sliders set for… so I was thinking that it would have to meet that quality before downloading… but now I see that it will no longer download epps once that quality is met…
I will set the sliders for the others and try again
Just a quick follow up to let other uses know that setting the quality sliders on the other quality definitions ticked in the quality profile fixed the problem
