Hi, I’ve just installed NZBDrone on my Synology NAS. At first I managed to get one episode downloaded and updated to Plex. I must have screwed something up while adjusting other settings, because I’ve got an episode of another show downloaded to /NZB Downloads/ that isn’t picked up when I click the “Update series info and scan disk” button. However if I manually copy the episode to either /NZB Downloads without the subfolder or to the folder that the episode should be moved to and click that button, the episode is deleted
I get these in the error log:
Couldn’t import episode /volume1/Shared Files/NZB Downloads/The.Colbert.Report.2014.05.01.Saul.Williams.720p.HDTV.x264-2HD/the.colbert.report.2014.05.01.saul.williams.720p.hdtv.x264-2hd.mkv: Access to the path is denied.
Couldn’t import episode /volume1/Shared Files/NZB Downloads/the.colbert.report.2014.05.01.saul.williams.720p.hdtv.x264-2hd.mkv: Error setting file permissions: EPERM
Unable to set last write time: Invalid parameter
I’ve repeated the test of copying the episode to both the upper folder and TV show folder, but it happens each time. After this I put a random show on to download, which got added to SABnzbd, had the right directories created and was copied to the right place. So I don’t know why it’s messing up on adding other files
