Sonarr version (exact version): Sonarr Ver. 2.0.0.5085
Mono version (if Sonarr is not running on Windows): 5.4.1.6
OS: Synology
Hi,
My sonarr installation got a problem yesterday, and everything got reinit. So i resetup everything and now I have a problem, I imported my shows from my hdd and now all my episodes are stuck in activity, when I move mouse over icon I have a message saying file is not imported because it has the same filesize as existing file (which is normal). How can I remove all this items? I don’t want to remove them from my download client (transmission)
Change the category they are in, which for transmission would be moving them to a different sub folder.
There is no other way than moving manually more than 900 items? If I move them, I will loose my hardlink?
Manually telling Sonarr to forcibly re-import the duplicates would also work, but that’d be more work.
If they’re on the same volume the hardlink won’t change. A symlink could break depending how it’s setup, but a hardlink is fine.
Thanks for the answer, I tried to move to another folder but doesn’t seems to work, so I’m currently reimporting everything.
