Episode searching in a wrong format
Sonarr version (exact version): 2.0.0.4949
Jackett version: 0.8.225.0
OS: Windows 10 Pro x64
((Debug logs)):
17-9-30 17:01:52.3|Info|NzbSearchService|Searching 2 indexers for [The Sinner : 2017-08-02]
17-9-30 17:01:52.3|Debug|Torznab|Downloading Feed http://localhost:9117/api/v2.0/indexers/thepiratebay/results/torznab/api?t=tvsearch&cat=5000,100205,5050,2040,100207,5040,100208&extended=1&apikey=(removed)&offset=0&limit=100&q=Sinner&season=2017&ep=08/02
17-9-30 17:01:52.3|Debug|Torznab|Downloading Feed http://localhost:9117/api/v2.0/indexers/ncore/results/torznab/api?t=tvsearch&cat=5030,5040&extended=1&apikey=(removed)&offset=0&limit=100&q=Sinner&season=2017&ep=08/02
17-9-30 17:01:54.7|Debug|NzbSearchService|Total of 0 reports were found for [The Sinner : 2017-08-02] from 2 indexers
17-9-30 17:01:54.7|Info|DownloadDecisionMaker|No results found
17-9-30 17:01:54.7|Info|EpisodeSearchService|Episode search completed. 0 reports downloaded.
Sonarr cant find episodes, I tested it with multiple series, multiple episodes It doesnt work. I dont know how to fix this problem. I tried everything.
It is searching like this [The Sinner : 2017-08-02]. I think it should be like this [The Sinner: S01E01]
Did you add regular series as daily series by any chance?
