Episode parsed wrong
I am running into an issue with The Blacklist, as you can see from the log below it is being parsed as TheBLACKLIST without a space, is this the problem and if so how do I fix it?
14-3-18 07:24:33.1|Debug|DiskScanService|Scanning ‘D:\Watch Folder Phase-2’ for video files
14-3-18 07:24:33.1|Debug|DiskScanService|1 video files were found in D:\Watch Folder Phase-2
14-3-18 07:24:33.2|Debug|Parser|Parsing string 'The Blacklist.S01E16.720p.HDTV.X264-DIMENSION’
14-3-18 07:24:33.2|Debug|Parser|Episode Parsed. theblacklist - S01E16
14-3-18 07:24:33.2|Debug|Parser|Language parsed: English
14-3-18 07:24:33.2|Debug|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for The Blacklist.S01E16.720p.HDTV.X264-DIMENSION
14-3-18 07:24:33.2|Debug|Parser|Quality parsed: HDTV-720p
14-3-18 07:24:33.2|Debug|Parser|Release Group parsed: DIMENSION
14-3-18 07:24:33.2|Debug|DownloadedEpisodesImportService|Unknown Series for file: D:\Watch Folder Phase-2\The Blacklist.S01E16.720p.HDTV.X264-DIMENSION.mp4
14-3-18 07:24:33.2|Debug|TaskManager|Updating last run time for: NzbDrone.Core.MediaFiles.Commands.DownloadedEpisodesScanCommand
Quote = markus101 :
The update today addressed an issue with two similarly named, but different shows (among other things), The Blacklist and Blacklist, due to this change series need to be refreshed (which happens automatically). Any show that starts with The, A, An, etc will be affected. And this was tested for a week prior to it going live, as most changes are.
Thats how drone has always compared titles, it removes, non-alpha numeric characters (spaces, dashes, colons, etc), removes some common words (a, the, an, of, etc), converts the title to lower-case and compares, the recent change leaves the common words at the beginning of the title, because there is at least one instance where shows have similar names, as mentioned.
Is there a reason why the space should be significant?
No reason, I thought that may be the problem., but when I had gotten home now it scanned and picked it up correctly. Not sure what the issue was earlier.
Thanks for your response.
@Deuce911 the quote @malcontent made from me, explains it. The refresh had to take place before it imported. In the future I’ll look for a way for force the refresh earlier if I can.
