This is the second time this has happened this week but I figure I would inquire about it now.
Anyway, ND downloaded Elementary.S02E02.Solve.for.X.[HDTV-720p].mkv last night and then today it grabbed Elementary.S02E02.Solve.for.X.[WEBDL-720p].mkv. They are both sitting in the season folder. It also happened with another series this week but I didn’t think much of it until now.
I can’t access the logs vi ND console. All I get when I go to logs > table view is the image thing moving back and forth. I can however access logs 3 and 4 but not 0, 1, 2 and 3.
Also,on another unrelated issue. I have the tv series Upper Middle Bogan quality set to SD but it is not grabbing the episodes for some reason. I had to do it manually and then ND sorted it out. Any idea why this is happening?
Thanks
Shedrock
Both files still exist on disk?
You can check the logs via the file system as well, they’re in ProgramData.
For the UI logs, but What version are you on? Try another browser? Clear your cache?
Check the logs as to why it’s not finding anything for that series, could be a number of things. Or do a manual search.
Both files still exist on disk.
This is all I can pull from the logs:
13-10-4 15:49:17.3|Trace|Parser|Parsing string 'Elementary.S02E02.720p.WEB-DL.DD5.1.H.264-ECI'
13-10-4 15:49:17.3|Trace|Parser|Episode Parsed. elementary - S02E02
13-10-4 15:49:17.3|Trace|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for Elementary.S02E02.720p.WEB-DL.DD5.1.H.264-ECI
13-10-4 15:49:18.2|Trace|CutoffSpecification|Comparing file quality with report. Existing file is WEBDL-720p
13-10-4 15:49:18.2|Trace|NotRestrictedReleaseSpecification|Checking if release contains any restricted terms: Elementary.S02E02.720p.WEB-DL.DD5.1.H.264-ECI
13-10-4 15:49:18.2|Trace|NotRestrictedReleaseSpecification|No restrictions apply, allowing: Elementary.S02E02.720p.WEB-DL.DD5.1.H.264-ECI
13-10-4 15:49:18.2|Trace|AcceptableSizeSpecification|Beginning size check for: Elementary.S02E02.720p.WEB-DL.DD5.1.H.264-ECI
13-10-4 15:49:18.3|Trace|AcceptableSizeSpecification|Item: Elementary.S02E02.720p.WEB-DL.DD5.1.H.264-ECI, meets size constraints.
13-10-4 15:49:18.3|Trace|ConfigService|Unable to find config key 'sabport' defaultValue:'8080'
13-10-4 13:46:10.9|Warn|MediaCoverMapper|File C:\ProgramData\zbDrone\MediaCover\260\poster.jpg not found
13-10-4 13:46:12.5|Trace|EventAggregator|Publishing UpdateQueueEvent
13-10-4 13:46:12.5|Trace|EventAggregator|UpdateQueueEvent → QueueModule
13-10-4 13:46:12.5|Trace|CommandExecutor|Publishing BroadcastSignalRMessage
13-10-4 13:46:12.5|Trace|CommandExecutor|BroadcastSignalRMessage → NzbDronePersistentConnection
13-10-4 13:46:12.5|Trace|EventAggregator|Publishing CommandExecutedEvent
13-10-4 13:46:12.5|Trace|EventAggregator|CommandExecutedEvent → TaskManager
13-10-4 13:46:12.5|Trace|EventAggregator|CommandExecutedEvent ← TaskManager
13-10-4 13:46:12.6|Trace|CommandExecutor|BroadcastSignalRMessage ← NzbDronePersistentConnection [00:00:00]
13-10-4 13:46:12.6|Trace|EventAggregator|UpdateQueueEvent ← QueueModule
13-10-4 13:46:13.1|Trace|ConfigService|Unable to find config key ‘sabusessl’ defaultValue:‘False’
13-10-4 13:46:13.1|Trace|ConfigService|Unable to find config key ‘sabport’ defaultValue:‘8080’
13-10-4 13:46:13.1|Trace|ConfigService|Unable to find config key ‘sabusername’ defaultValue:‘’
13-10-4 13:46:13.1|Trace|ConfigService|Unable to find config key ‘sabpassword’ defaultValue:‘’
13-10-4 13:46:13.1|Trace|Parser|Parsing string ‘Elementary.S02E02.720p.WEB-DL.DD5.1.H.264-ECI’
13-10-4 13:46:13.1|Trace|Parser|Episode Parsed. elementary - S02E02
Version of ND: NzbDrone Ver. 2.0.0.656 - develop
I don’t see anything on Upper Middle Bogan besides the manual executed search I did in order to find it.
