Episode Not being Moved by ND
I have an episode of The Vampire Diaries which seems to be named perfectly normal yet ND has not grabbed and moved it to the correct folder it is still sitting in the Drone Factory folder
this is a show that has correct naming and all the other weeks has picked up the episodes and moved them just not this one it has been more than 24 hours and it is still there
I know i can easily manually move it but i am wondering if this is going to happen again here is a screenshot of how it looks in the drone factory folder
does anyone see a naming format issue this is how it was downloaded and is named by the capping group
Looks fine to me, try turning on trace logging, deleting the existing logs and running it again.
Okay done that and this is what i get
It is just weird all of a sudden i have got the rest of the season just fine as well as the previous seasons just for some reason this time
It could just be a fluke occurence and like i said i could easily manually do it but just curious as to why seeing as i didn’t see anything wrong with the naming and neither did you
Trace logs only show up in log files, will need to see the import process in there for more information.
okay here is copy of trace it mentioned the episode towards the bottom
http://tny.cz/46f427b8
it think this is the part you are probably looking at
13-11-3 10:55:34.1|Trace|Parser|Parsing string 'the.vampires.diaries.505.hdtv-lol’
13-11-3 10:55:34.1|Trace|Parser|Episode Parsed. vampiresdiaries - S05E05
13-11-3 10:55:34.1|Trace|NzbDrone.Core.Parser.QualityParser|Trying to parse quality for the.vampires.diaries.505.hdtv-lol
13-11-3 10:55:34.2|Debug|DownloadedEpisodesImportService|Unknown Series for file: D:\ZBDRONE\the.vampires.diaries.505.hdtv-lol.mp4
Missed the issue on the first few looks, the issue is: the vampires diaries (note the s on the end of vampires). Not sure if thats a common scene name for it, first time I’ve seen it.
ah ok will just manually rename it and see if it happens again thanks mate :slight_smile:
