Episode enumeration mismatch... how to deal with it? (s2009x40 vs s03e23, etc)
So I came over to NZBD specifically because SB couldn’t find Pawn Stars and I read someone’s post that it was found just fine here. Well, guess what? I’m having the exact same problem here. The issue, of course, is that TVDB lists series one way and “scene” lists them another way. Is there an answer for this here? If so, can someone walk me through what to do? Thanks.
Drone uses thexem.de to do the mappings. This is the config for Pawn Stars: http://thexem.de/xem/show/802
Drone will treat any file in the drone factory folder (downloaded, but not sorted) or from an indexer as having the scene numbering, anything in the final series folder (sorted) is assumed to have the tvdb numbering.
Sorry I’m not following. I mean… shouldn’t it just work then? The mapping is there, but its not find’ing any episodes.
oh weird… like my other bug report (http://forums.nzbdrone.com/discussion/717/bug-report-couldn039t-save-notification-when-defining-sabnzdb-download-client#Item_5 how do I make nice links on this forum???), this resolved itself with a service reload.
Yes, searching should work, as long as that episode is mapped properly. The mapping refreshes when the series is updated, but thats not tied to a restart of the app.
Posts use markdown, http://daringfireball.net/projects/markdown/syntax#link shows how to do it.
