Jeopardy rarely downloads automatically for me. I usually get an error stating “episode does not match” Attached are screenshots of how I have everything setup. This is really the only show that I have issues with.
You have it set as a daily series, but S2015E158 is used to label the episode, the date is there as well, but S2015E158 is preferred to Sonarr.
Does the behavior change if you select the series type as standard?
Seems like that fixed the issue. Thanks Markus!
