I had a season auto replaced by incorrect language. S01E01 was correctly replaced with a 720p bluray reward rip. E02 onwards was replaced by 720p german? dubbed itunes hd rips.
Californication - S01E09 - Filthy Lucre [HDTV-720p].mkv
was replaced by
Californication.S01E09.Schnoeder.Mammon.DL.Dubbed.720p.iTunesHD.AVC-WOLF
and renamed to
Californication - S01E09 - Filthy Lucre [WEBDL-720p].mkv
On another note - is there any way to set a profile to treat two quality types as equal priority? I have prioritised Bluray > Web dl > hdtv and am finding that many eps are grabbed in hdtv only to be replaced by the delayed web dl release on the same day.
Add dubbed to the must nor contain list for a global profile to prevent it from happening again, without the language in there Sonarr treats it as English.
No, but you could use delay profiles to delay the grab of the HDTV release to allow the WEBDL time to be grabbed first.
Thanks for your helpful and quick response as usual. Added dubbed to restrictions to avoid that in the future. Hope it doesn’t mess up anime or other english dubbed releases too much.
Some shows are random as to whether hdtv or webdls are upped first. Some have hdtv’s first and a set time interval for webdl, some shows are inconsistent as to whether there are even webdls upped for every episode, or the interval time until they are upped.
Can you consider a feature request for a tickbox for “only replace existing files with cutoff quality”. This would allow more freedom in the quality profiles as well as cut down a lot of wasted bandwidth and save people having to do custom timers or profiles for each show. Thanks.
