Has been doing this for the last few days, this last time it got absurd. It has grabbed the EXACT same release from 3 different indexers. I hunted the first 2 & both even show as excepted.
I dont see how this thing is confused on this one, all 3 are the exact same (not even different release groups)
All 3 where automatic grabs (green download arrow signifies grab vs manual)
20-5-10 20:10:21.5|Info|DownloadDecisionMaker|Processing 253 releases
20-5-10 20:10:21.5|Debug|DownloadDecisionMaker|Processing release 'The.Simpsons.S31E21.1080p.WEB.X264-ALiGN' from 'DigitalCore'
20-5-10 20:10:21.5|Debug|Parser|Parsing string 'The.Simpsons.S31E21.1080p.WEB.X264-ALiGN'
20-5-10 20:10:21.5|Debug|Parser|Episode Parsed. The Simpsons - S31E21
20-5-10 20:10:21.5|Debug|Parser|Language parsed: English
20-5-10 20:10:21.5|Debug|QualityParser|Trying to parse quality for The.Simpsons.S31E21.1080p.WEB.X264-ALiGN
20-5-10 20:10:21.5|Debug|Parser|Quality parsed: WEBDL-1080p v1
20-5-10 20:10:21.5|Debug|Parser|Release Group parsed: ALiGN
20-5-10 20:10:21.5|Debug|AcceptableSizeSpecification|Beginning size check for: The.Simpsons.S31E21.1080p.WEB.X264-ALiGN
20-5-10 20:10:21.5|Debug|AcceptableSizeSpecification|Max size is unlimited, skipping size check
20-5-10 20:10:21.5|Debug|AcceptableSizeSpecification|Item: The.Simpsons.S31E21.1080p.WEB.X264-ALiGN, meets size constraints
20-5-10 20:10:21.5|Debug|AlreadyImportedSpecification|Performing already imported check on report
20-5-10 20:10:21.5|Debug|AlreadyImportedSpecification|Skipping already imported check for episode without file
20-5-10 20:10:21.5|Debug|LanguageSpecification|Checking if report meets language requirements. English
20-5-10 20:10:21.5|Debug|MaximumSizeSpecification|Maximum size is not set.
20-5-10 20:10:21.5|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
20-5-10 20:10:21.5|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. WEBDL-1080p v1
20-5-10 20:10:21.5|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: The.Simpsons.S31E21.1080p.WEB.X264-ALiGN
20-5-10 20:10:21.5|Debug|ReleaseRestrictionsSpecification|[The.Simpsons.S31E21.1080p.WEB.X264-ALiGN] No restrictions apply, allowing
20-5-10 20:10:21.5|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
20-5-10 20:10:21.5|Debug|DelaySpecification|QualityProfile does not require a waiting period before download for Torrent.
20-5-10 20:10:21.5|Debug|HistorySpecification|Performing history status check on report
20-5-10 20:10:21.5|Debug|HistorySpecification|Checking current status of episode [40388] in history
20-5-10 20:10:21.5|Debug|DownloadDecisionMaker|Release accepted
20-5-10 20:10:21.5|Debug|DownloadDecisionMaker|Processing release 'The.Simpsons.S31E21.720p.WEB.X264-ALiGN' from 'DigitalCore'
20-5-10 20:10:21.5|Debug|Parser|Parsing string 'The.Simpsons.S31E21.720p.WEB.X264-ALiGN'
20-5-10 20:10:21.5|Debug|QualityParser|Trying to parse quality for The.Simpsons.S31E21.720p.WEB.X264-ALiGN
20-5-10 20:10:21.5|Debug|Parser|Quality parsed: WEBDL-720p v1
20-5-10 20:10:21.5|Debug|AcceptableSizeSpecification|Beginning size check for: The.Simpsons.S31E21.720p.WEB.X264-ALiGN
20-5-10 20:10:21.5|Debug|AcceptableSizeSpecification|Item: The.Simpsons.S31E21.720p.WEB.X264-ALiGN, meets size constraints
20-5-10 20:10:21.5|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. WEBDL-720p v1
20-5-10 20:10:21.5|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: The.Simpsons.S31E21.720p.WEB.X264-ALiGN
20-5-10 20:10:21.5|Debug|ReleaseRestrictionsSpecification|[The.Simpsons.S31E21.720p.WEB.X264-ALiGN] No restrictions apply, allowing
20-5-10 20:10:23.7|Debug|QBittorrent|Downloading torrent for episode 'The.Simpsons.S31E21.1080p.WEB.X264-ALiGN' finished (29738 bytes from http://127.0.0.1:9117/dl/digitalcore/?jackett_apikey=(removed)&path=Q2ZESjhEa3pjTGtMcWpKRXNlZmtVQlpWRUtHZFVFWHNIWTFDc0NOOURNcDdOTDZETHc2R24yR25zU0QyOUx3dW9Ia2h3Zm8zdW1FZGphMGlobWxWTGZuNThnOUtmQmpMSGFzQUpyQ2tDRDY1UzFEdDhtdkZWTG1pNU9QLWF0VGhYcy15S0VIWnVKWEdoUy1uM3JKZVRSX3ZpY19WYmFuYmszbzVwVF9ETFgxV3lMOExUd2VrNEpUSEJnRkpHVGxuWWdwRkt3&file=The.Simpsons.S31E21.1080p.WEB.X264-ALiGN)
20-5-10 20:10:23.7|Info|DownloadService|Report sent to qBittorrent. The.Simpsons.S31E21.1080p.WEB.X264-ALiGN
20-5-10 20:43:23.9|Debug|DownloadDecisionMaker|Processing release 'The Simpsons S31E21 1080p WEB X264-ALiGN' from 'Speed'
20-5-10 20:43:23.9|Debug|Parser|Parsing string 'The Simpsons S31E21 1080p WEB X264-ALiGN'
20-5-10 20:43:23.9|Debug|Parser|Episode Parsed. The Simpsons - S31E21
20-5-10 20:43:23.9|Debug|Parser|Language parsed: English
20-5-10 20:43:23.9|Debug|QualityParser|Trying to parse quality for The Simpsons S31E21 1080p WEB X264-ALiGN
20-5-10 20:43:23.9|Debug|Parser|Quality parsed: WEBDL-1080p v1
20-5-10 20:43:23.9|Debug|Parser|Release Group parsed: ALiGN
20-5-10 20:43:24.0|Debug|AcceptableSizeSpecification|Beginning size check for: The Simpsons S31E21 1080p WEB X264-ALiGN
20-5-10 20:43:24.0|Debug|AcceptableSizeSpecification|Max size is unlimited, skipping size check
20-5-10 20:43:24.0|Debug|AcceptableSizeSpecification|Item: The Simpsons S31E21 1080p WEB X264-ALiGN, meets size constraints
20-5-10 20:43:24.0|Debug|AlreadyImportedSpecification|Performing already imported check on report
20-5-10 20:43:24.0|Debug|CutoffSpecification|Comparing file quality and language with report. Existing file is WEBDL-1080p v1 - English
20-5-10 20:43:24.0|Debug|UpgradableSpecification|Comparing preferred word score. Current: 0 New: 19
20-5-10 20:43:24.0|Debug|LanguageSpecification|Checking if report meets language requirements. English
20-5-10 20:43:24.0|Debug|MaximumSizeSpecification|Maximum size is not set.
20-5-10 20:43:24.0|Debug|MinimumAgeSpecification|Not checking minimum age requirement for non-usenet report
20-5-10 20:43:24.0|Debug|QualityAllowedByProfileSpecification|Checking if report meets quality requirements. WEBDL-1080p v1
20-5-10 20:43:24.0|Debug|ReleaseRestrictionsSpecification|Checking if release meets restrictions: The Simpsons S31E21 1080p WEB X264-ALiGN
20-5-10 20:43:24.0|Debug|ReleaseRestrictionsSpecification|[The Simpsons S31E21 1080p WEB X264-ALiGN] No restrictions apply, allowing
20-5-10 20:43:24.0|Debug|RetentionSpecification|Not checking retention requirement for non-usenet report
20-5-10 20:43:24.0|Debug|UpgradeAllowedSpecification|Comparing file quality and language with report. Existing file is WEBDL-1080p v1 - English
20-5-10 20:43:24.0|Debug|UpgradeDiskSpecification|Comparing file quality and language with report. Existing file is WEBDL-1080p v1 - English
20-5-10 20:43:24.0|Debug|UpgradableSpecification|New item has a better preferred word score
20-5-10 20:43:24.0|Debug|DelaySpecification|QualityProfile does not require a waiting period before download for Torrent.
20-5-10 20:43:24.0|Debug|HistorySpecification|Performing history status check on report
20-5-10 20:43:24.0|Debug|HistorySpecification|Checking current status of episode [40388] in history
20-5-10 20:43:24.0|Debug|DownloadDecisionMaker|Release accepted
I see New item has a better preferred word score
however:
- My release profiles have not changed
- The first one it downloaded was actually a score of 20 which would have been higher so not sure why it says 0 (Digitalcore = 20, Speed = 19, IPT = 18, Torrentday = 17)
- It is the exact same release, name/size/group/etc so why would it even try to download it again anyways!!??!! Maybe if there where a higher quality but it is identical.
Edit - Now as of this morning it grabbed rick and morty 3 times & the rookie FIVE damn times
