3.0.6.1265:
5.20.1.34:
DSM7:
Shows download but stuck importing:
Hi,
I’ve done the upgrade to DSM7 and SABnzdb has got a proper release as of the last 48 hours. Sonarr find the shows and gives the job to sab…this works. Coincidentally, the same happens with Radarr as well. so I suspect that this is more to do with DSM7 than it is with these packages.
When I look in Sonarr, I can see the the download has finished but the job is stuck at “Downloaded - Importing” this means that the tasks that move and rename files, as well as deleting the folder that it was in previously don’t run.
I’ve checked in events and log and there’s no mention of there being a permissions issue.
sc-download has read/write permissions to the relevant folders and subfolders.
I have also done a complete uninstall/reinstall of this package via the package manager.
Not sure if this is a known issue or I’m first one reporting it.
I can live with manually doing this myself for now, but for those that can’t then this would be helpful to them.
Let me know.
Cheers,
Junkt0wn
