DS indexer not working
Version 4.0.10.2544-ls258 by linuxserver.io
OS: Ubuntu
Debug logs: PrivateBin
I had DS working without issues a few weeks ago. My subscription ran out so logically it stopped working. With BF I upgraded my account again and should be able to work without any issues. My connection with DS seem to work fine via other arr programs like lidarr for example.
For some reason it does not want to connect however in Sonarr. I go to my indexer settings, press test and it just keeps on loading.
Other indexers are working just fine.
DS profile is also not at it’s limit: API Hits Today: 402/1000
If I try to set it up as a new indexer, it’s giving me the loading issue right from when I enter the URL.
Does anyone have any thoughts?
Logs show no errors?
Start be correcting your url
2024-11-19 21:35:31.2|Trace|HttpClient|Res: HTTP/2.0 [GET] https://api.drunkenslug.com/api?t=caps&apikey=(removed) 301.Moved (167 bytes) (16 ms)
2024-11-19 21:35:31.2|Trace|HttpClient|Redirected to https://drunkenslug.com/api?t=caps&apikey=(removed)
I let it run longer this until it would just time out.
Here is an updated trace with possibly more info.
PS: I am unable to update the url, when I change the url the same issue happens and the indexer screen just keep loading until it timeouts.
If I use another indexers url, it works just fine but get an API key conflict error which makes sense.
So it seems to really only give conflicts when entering the DS url.
Either api.drunkelslug.com and also drunkenslug.com
Extra info:
Steps I follow to reproduce.
  1. In Sonarr Settings > Indexers > Add Indexer
  2. Under Usenet, Newznab select the preset DrunkenSlug.
  3. The moment I select it I can already see Sonarr is unable to gather the Categories selections. It’s just showing a loading icon in that field.
Even though I had restarted Sonarr before, after the 4th time it worked again…
