I am having a weird issue, which i think is more widely spread (will try and find more similar samples)
I use only one provider, since i had strange issues with others (passworded releases and/or fakes etc etc). thus currently stuck on Oznzb. Problem is, over the past two weeks, i had to frustratingly see that some shows is just never found - in most cases the SD episode is just never there.
switching quality to 720p all of a sudden produces results, but , i cant afford the 3 to 4 times increase in data.
I found and investigated now one sample. and it seems the cuplrit is the release id on OzNzb.
I have included my log file ( on trace), and a capture for a manual search on the website.
is there a way for drone to adapt, or will i get better results from the OznNZB team to fix the API ( i am just not sure how to phrase my question to them…)
, it seems like the following two important attributes is not set for the SD variant
newznab:attr name=“season” value="S03"
newznab:attr name=“episode” value=“E02”
guess this is not fixable, since season and episode numbers is quite important
Drone uses the tvrage id when searching (you can see the tvrage id drone has on the series details page by hovering over the TVRage link under the overview).
If manual search results don’t show the SD release its possible it doesn’t have the correct TV rage id associated with it on the indexer. Drone will show all the results it find when searching in the manual search results list and why it was rejected (which would prevent auto search from grabbing it).
If you compare that release with the 720p one, you will also see that the 720p one contains the season/episode number, but the SDTV one doesn’t, maybe it didn’t parse properly on their end?
You should change your oznzb API key because its in the URL you posted contains it.
