I’ve noticed in the past couple of days I’ve been lucky to only get 1 result when doing a manual search (And presumably automatic searching as well)
I enabled trace debugging and noticed that almost everything is being filtered. In this example I am only getting 1 result when there is a clearly several more valid results being sent by newznab.
Hell on Wheels 2014 is utterly wrong, looks like QoQ is adding the season year,which is crazy.
Please enter the url in your browser.
Check the <guid> fields of the results. I suspect they’re the same. If there aren’t <guid> fields lemme know too.
In a recent version we started to identify releases by guid (either the provided one or randomly generated).
Since then we’re also combining search results with the same guid. This particularly helps when we have to hit the search api with multiple different queues to get all results for a odd show/indexer.
Yes, adding a random guid in Megasearch is the best option. But some indexers simply put the nzb download url in there, others the link to the info site. I rarely see a real Guid.
As long as it’s unique.
