I received an error in my log saying the Drone Factory does not exist, but I cannot for the life of me, find a setting to disable it.
I’m not the most savvy with this stuff yet, but I should be able to find a setting that will allow me to change/turn off Drone Factory, so there is no conflict with Sonarr doing Handling.
Drone Factory was the primary method of import until mid last year, when we moved to Completed Download Handling.
At that time we changed Drone factory to an advanced option, only to be used for custom manual imports:
You can clear the field or set it to some empty directory where you can dump stuff downloaded via other means.
