Sonarr version (exact version): 3.0.1.467
Mono version (if Sonarr is not running on Windows): 5.16.0.220
OS: OOSX 10.14.4
Sonarr is telling my download client to download. However, sometimes it doesn’t copy the files over to the folder where the seasons are. Sometimes it will copy them but not delete the old files.
I have had the problem with copying and not deleting sometimes with utorrent and the reason for this was in my case was that the file was still seeding when sonarr wanted to move it so it copied it and then when utorrent was done seeding the files where still there because sonarr was already done with them. As for a solution the best i found was just manually deleting them and the reason for this is that the auto deleting solutions i found would most times delete it to fast and then you would have to download it again in sonarr and hope it would not get deleted.
There probably is a better solution then sometimes manually deleting and if you know of one please let me know as well.
