Can anyone advise on how to set up a TAG to be able to download x265 10bit series. I did already successfully using tags for retrieving x265/h265/HEVC releases, however, was thinking about 10bit releases. My understanding that only 1 tag will be considered when Sonarr is searching for the release. Therefore, I cannot assign 2 tags (first for x265 and the second for 10bit) to the series. Correct me if I’m wrong.
Would it be a good idea for hardcoding all these parameters (x265/x264, 8bit/10bit/12bit) in the same way we have resolutions hardcoded?
Thanks.
Restriction 1:
- Must contain: x265
- Tags: x265_10bit
Restriction 2: - Must contain: 10bit
- Tags: x265_10bit
Apply the x265_10bit tag to series.
Note: I have no idea what 10bit is. I make the assumption that it is a word in the release name.
Note 2: you could also separate both restrictions with an x265 and 10bit tag, and then apply both tags to series for the same result. With the restriction profiles above you only have to apply a single tag to series rather than two…
