Sonarr version (exact version): 3.0.4.1023
Mono version (if Sonarr is not running on Windows): 6.10.0
OS: Unraid 6.8.3
Debug logs: https://pastebin.com/KfNvfP6V
I seem to be having issues downloading nzb files from my indexer which in turn disables the indexer due to failures.
Here is the relevant parts of the log:
20-12-21 12:32:02.2|Error|Sabnzbd|Downloading nzb for episode ‘Le*****.S01E09.720p.HDTV.x264-W4F’ failed (http://192.168.1.217:5075/getnzb?apikey=(removed)&searchresultid=80002e1efbc694asdfue234j75f3ec4)
[v3.0.4.1023] System.Net.WebException: Error: ProtocolError: 'https://api.omgwtfnzbs.me/api?t=get&id=Cih87gkr&apikey=(removed) —> System.Net.WebException: Error: ProtocolError
at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x0015e] in /build/mono/src/mono/mcs/class/System/System.Net/WebConnection.cs:282
If I enter the url of either directly they both work fine. I recently upgraded to v3 in attempt to fix this issue as it was also happening before I upgraded.
Fyi, I’m also using the exact same setup for Radarr and it works fine as well.
My current setup involves Sonarr 3 > Hydra 2 (sole indexer) > Sabnzbd with VPN using privoxy
Thx
