Sonarr version (exact version): 3.0.6.1265
OS: Windows 10
Hi all,
I had my system working perfectly, but sometime over the last 2-3 weeks it will no longer move or rename completed jobs.
My system is a bit unique: I have SABnzb and Sonarr running on one machine, and writing to a large nas on the same network.
SABnzb and Sonarr are both invoked via a command line script once the NAS is mounted to w: etc
start “” “C:\Program Files\SABnzbd\SABnzbd.exe”
start “” “C:\ProgramData\Sonarr\bin\Sonarr.exe”
In the w: share, I have the following directory structure:
_Downloads
_Downloads_Completed
_Downloads_Temp
TV (Where my library is)
SABnzbd uses the _Temp Folder for downloads, and the _Completed folder for, well, completed downloads. I have a category for “sonarr” set with w:\TV.
No mater what I’ve tried, I cannot get the downloaded file to be renamed and sorted into the appropriate library folder as it had been doing. I don’t know what changed, just that it stopped working.
The result of this is that I end up with a folder sitting in my W:\TV called
The.Simpsons.S31E04.720p.HEVC.x265-MeGusta
Instead of the enclosed video file sorting into
The Simpsons\Season 31\The Simpsons - S31E04 - Treehouse of Horror XXX.mkv
2021-07-14 16:13:37.5|Debug|Sabnzbd|Downloaded nzb for episode 'The.Simpsons.S31E04.1080p.HEVC.x265-MeGusta' finished (43648 bytes from https://api.nzbplanet.net/getnzb/796294594ebc6d91477210f4074a7132.nzb&i=374404&r=(removed)
2021-07-14 16:13:37.5|Info|Sabnzbd|Adding report [The.Simpsons.S31E04.1080p.HEVC.x265-MeGusta] to the queue.
2021-07-14 16:13:37.5|Debug|SabnzbdProxy|Url: http://localhost:48080/api?mode=addfile&cat=sonarr&priority=-100&apikey=(removed)&output=json
2021-07-14 16:13:37.7|Info|DownloadService|Report sent to SABnzbd. The.Simpsons.S31E04.1080p.HEVC.x265-MeGusta
2021-07-14 16:13:37.7|Debug|Api|[POST] /api/v3/release: 200.OK (910 ms)
2021-07-14 16:13:42.7|Debug|SabnzbdProxy|Url: http://localhost:48080/api?mode=queue&start=0&limit=0&apikey=(removed)&output=json
2021-07-14 16:13:42.7|Debug|SabnzbdProxy|Url: http://localhost:48080/api?mode=history&start=0&limit=60&category=sonarr&apikey=(removed)&output=json
2021-07-14 16:13:42.7|Debug|Parser|Parsing string 'The.Simpsons.S31E04.1080p.HEVC.x265-MeGusta'
2021-07-14 16:13:42.8|Debug|Parser|Episode Parsed. The Simpsons - S31E04
2021-07-14 16:13:42.8|Debug|Parser|Language parsed: English
2021-07-14 16:13:42.8|Debug|QualityParser|Trying to parse quality for The.Simpsons.S31E04.1080p.HEVC.x265-MeGusta
2021-07-14 16:13:42.8|Debug|Parser|Quality parsed: HDTV-1080p v1
2021-07-14 16:13:42.8|Debug|Parser|Release Group parsed: MeGusta
2021-07-14 16:13:42.8|Debug|TrackedDownloadService|Tracking 'SABnzbd:The.Simpsons.S31E04.1080p.HEVC.x265-MeGusta': ClientState=Downloading SonarrStage=Downloading Episode='The Simpsons - S31E04 HDTV-1080p v1' OutputPath=.
2021-07-14 16:13:42.8|Debug|Api|[GET] /api/v3/queue/details?seriesId=73: 200.OK (1 ms)
2021-07-14 16:13:42.8|Debug|Api|[GET] /api/v3/command: 200.OK (7 ms)
2021-07-14 16:13:42.8|Debug|Api|[GET] /api/v3/queue/details?seriesId=73: 200.OK (3 ms)
2021-07-14 16:13:42.8|Debug|Api|[GET] /api/v3/command: 200.OK (1 ms)
It downloads the file fine - it just doesn’t rename it or move it appropriately. Thanks for the help in advance.
