Downloaded episodes not going into the correct show folder
Ever since I’ve converted to NZBDRONE v2, none of the newly downloaded episodes are going into their perspective show folder.
For example, Covert Affairs has its path set to G:\TV\Covert Affairs. However, whenever an episode is downloaded, it gets put into G:\TV\Covert.Affairs.S04E07.720p.HDTV.x264-EVOLVE (for example). I have setup the Nzbdrone to monitor and use season folder.
I went though all the configs and can’t figure out why that is. Any ideas? What config am I missing?
TIA!
I should add that I use SABNzbd
Sounds like SAB is downloading to your TV Show folder and NzbDrone isn’t sorting the files at all, please see: https://github.com/NzbDrone/NzbDrone/wiki/Sorting-and-Renaming
