Download client monitoring for complete downloads
Hi all, i’m not sure if this is a bug or if it’s just me. I only download from usenet and most of the time my media storage is in sleep mode so sonarr can’t move it until I wake it up.
I’ve noticed since the October 18th update that the Wanted page, once a download completes, shows that the episode is missing from disk. Before the update it would show the purple bar as full, suggesting it knows that the download is complete but can’t be moved due to missing storage.
It still seems to handle this OK and doesn’t re-download stuff but on those occasions it can’t find a suitable download and I select a manual one I may end up trying to download something it’s already grabbed without realising.
Any advice would be great, or is it just a bug??
Thanks!
Is Completed Download Handling enabled? If not this is expected, if so get us some trace logs after a finished download while the storage is offline.
Looks like I must have turned off Completed Download Handling at some point, re-enabling that has fixed it!
Thanks :slight_smile:
