This guy here: https://github.com/Sonarr/Sonarr/wiki/FAQ doesn’t seem to mention anything about Double episodes or… multiple downloads of the same episode… ooor… well… the closest thing I found was…
People keep talking about “CDH” but none mention anything about it other than the acronym…
I’m not looking to collect shows… acquire them for all time…
I just want to tell the app what I want & it goes to fetch… & fetches the new episodes of the shows I watch as they come out based on my quality preference…
Once I delete them… gone forever…
Which I’ve also noticed even after deleting an episode of a new show I’ve watched on a series with Future enabled… sometimes it will still grab them additional times…
I seem to recall enabling an option… something to the tune of when I delete an episode… mark it as burned or some such thing…
The multiple copies of shows though is maddening… I find myself looking through my folders after I’ve watched a show to see if there are any other copies hiding anywhere… heh
This is expected behaviour with seeding torrents (as explained in the ((FAQ))). You can have Sonarr clean up torrents that have finished seeding automatically if you enable Remove Completed Downloads or you can remove them from Deluge manually.
oh I see… well then I was thinking Sonarr would be moving the downloads as they completed to the show & season folders so that’s what had me thinking something was wrong…
Methinks alls well now… we’ll see how tonight’s downloads go… tyvm
Uhm… so I’ve got one other not so much issue but curiosity & I think I’m set…
I only reference this thread because it mentions being able to seed to a certain % before removing the downloads…
I don’t see any places to configure that in Sonarr or Deluge… is it a torrent client feature so maybe I’d have to use uTorrent or something supporting it ?
As it stands now with Remove Completed Downloads enabled… what does it attempt to seed torrents to without any settings mods since I can’t seem to find where to anyway…
The default ratio or one I set… is there any time frame options for a threshold on when that ratio may or may not be met ?
I wouldn’t want stagnant torrents just sitting there that will never seed up 1:1 or better… which I suppose I can remove manually from time to time if that’s the current way of it…
If I can adjust my seed settings… it would be ideal if I could set different indexers I’m using with different seed stats… is that something I could do ?
Are the episodes ignored in Sonarr?
When you delete it are you deleting the whole folder or just the file? If you delete the whole folder Sonarr won’t see it as missing as it doesn’t rescan the series folder if it’s missing.
((Debug logs)) of the subsequent grabs would be the first step to investigate further.
