Don't look for higher quality?
Hi-
I have many TV shows that are in SD format and even though I would like HD-720p for all future episodes, I don’t want Drone to look for and download old TV shows. I can’t find an option in the Settings for this or by editing a TV show.
I know a feature of Drone is to automatically look for higher quality episodes, but in some cases, I would not like for this to happen. :slight_smile:
Maybe I am missing something? Thanks so much!
you can turn off the bookmarks for episodes that you don’t want nzbdrone to monitor (A.K.A keep a look out for)
these can be found on the left hand side either next to individual episodes or you can turn off an entire season or show at a time by simply unchecking the corresponding bookmark which when shaded or dark is switched on or when just an outline it means it is turned off
Oooh, there it is! I feel dumb. N00b over here!
Thanks so much!
No problem it took me a little while myself to work out that feature when it was first introduced :slight_smile:
So with 152 different shows, it’s a little cumbersome to have to go into each show, and each season to turn off bookmarking.
Anyway to have a setting not bookmark seasons when importing?
Edit: Looks like that is what Season Pass is for. Another doh!
Or setting the starting season when importing.
Ahh, so that’s what that drop down box is. Thank you!!!
