DogNzb Not working
cannot seem to get Dognzb API to work here is what i get (i have changed api several times so no issue about me posting here)
An error occurred while processing feed. https://dognzb.cr/api?t=tvsearch&cat=5030,5040&extended=1&apikey=fafebc12cf7b0f57ab52ee13828d71e3: Newznab error detected: API Disabled
Indexer doesn’t appear to be Newznab based: Newznab error detected: API Disabled: Newznab error detected: API Disabled
i have tried deleting indexer profile and re-adding but it will not let me re-add it i am using is https://dognzb.cr
Read their home page :slight_smile: The URL changed. It should be fixed in the latest versions of drone though.
thanks don’t really visit the site much mostly use the API so wasn’t sure what was going on i found the address in the forums
i cannot say if it is fixed in latest version of nzbdrone i am running the develop and did see the changelog about it but when i looked at the indexer settings it still had the old one but no drama’s just changed it to the corrected address and worked first time :slight_smile:
