Version 2.0.0.5322
Mono Version 5.20.1.19
TOS 4 (Terramaster NAS)
LOGS https://justpaste.it/6wamo
Hi,
I have both transmission and sonarr running on docker containers, both applications runs ok, and share the same IP address, 192.168.1.43
I can connect to transmission web interface from my computer on address [http://192.168.1.43:9091/transmission/web] and to sonarr on address [http://192.168.1.43:44358] so when I try to configure transmission as my download client in sonarr I put 192.168.1.43 on address, 9091 on port , my username and my password for rpc as configured on setting.json file but when I test the connection it fails, on logs it says connection timeout,
I tried to use localhost on address then the error message is ConnectFailure (Connection refused)
I also tried to disable rpc authentication and the problem is the same.
Any help would be appreciate.
