Mono version (if Sonarr is not running on Windows):5.20.1.34
OS: Debian 10
Invalid request Validation failed:
– Path does not exist
I am trying to get sonarr (and radarr for that matter) to work with my cifs mounted datastores. I am having these mounted at boot and the user I am using has r/rw permissions which has been verified by creating files/folders. I was previously mounting the CIFS to /media/tv which sonarr found but was having write issues with. So I altered it to mount to /home/user/tv-source which was a shortcut to get around the mountpoint permissions challenge. I also heard about some things not working if the share and the mount point were the same folder name.
However now, the webui won’t even recognize the existence of the mount points even when they clearly exist in the system. I have built the container with the -e PUID and -e PGID flags so I would expect it to have the same permissions as that user which is apparently not happening.
“ls /home/user/tv-source” works to list the datastore of TV series.
docker create
–name=sonarr
-e PUID=1000
-e PGID=1000
-e TZ=America/Chicago
-e UMASK_SET=022 #optional
-p 8989:8989
-v /path/to/data:/home/user/sonarr/config
-v /path/to/tvseries:/home/user/tv-source
-v /path/to/downloadclient-downloads:/home/user/sonarr/downloads
–restart unless-stopped
linuxserver/sonarr
Is the path relative or something? Any suggestions for getting this to work would be appreciated.
