Sonarr version (exact version): 3.0.8.1507
OS: Ubuntu Server 20.04
Debug logs: NA
Description of issue: Disk space is not updating when media is connected using glusterfs. When looking at Status I can see the disks being seen are my boot disk and the actual raid disk that is part of the Gluster cluster but the total disk size of the cluster isn’t being represented under Disk Space. When I checked the root folder to try to remove and re-add it, it already state’s there’s X TB’s available, which is the correct amount, but that’s showing the mount point space available and not the physical disk size. I did try running health check and restarting the service a few times, no change.
If Sonarr was checking the mount point as the source, I believe the storage amount would show correctly.
There was nothing relevant in the debug logs, but I can post some if requested.
