Finally got a chance to sit down and see that Sonarr hasn’t been running for a few days. Got it started, saw missed episodes on the calendar. Went to Wanted retrieved all missing. Went back to Calendar and IE said there was blocked content. Unblocked content and Sonarr broke. Just to verify, I tried with Chrome as well and received the same error.
"message": "disk I/O error\r\ndisk I/O error",
"description": "System.Data.SQLite.SQLiteException (0x80004005): disk I/O error\r\ndisk I/O error\r\n at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)\r\n at System.Data.SQLite.SQLiteCommand.BuildNextCommand()\r\n at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)\r\n at System.Data.SQLite.SQLiteDataReader.NextResult()\r\n at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)\r\n at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)\r\n at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior)\r\n at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()\r\n at System.Data.SQLite.SQLiteConnection.Open()\r\n at Marr.Data.DataMapper.OpenConnection() in m:\\BuildAgent\\work\\6c3239faf2b92630\\src\\Marr.Data\\DataMapper.cs:line 844\r\n at Marr.Data.DataMapper.Query[T](String sql, ICollection`1 entityList, Boolean useAltName) in m:\\BuildAgent\\work\\6c3239faf2b92630\\src\\Marr.Data\\DataMapper.cs:line 566\r\n at Marr.Data.QGen.QueryBuilder`1.ToList() in m:\\BuildAgent\\work\\6c3239faf2b92630\\src\\Marr.Data\\QGen\\QueryBuilder.cs:line 279\r\n at Marr.Data.QGen.SortBuilder`1.ToList() in m:\\BuildAgent\\work\\6c3239faf2b92630\\src\\Marr.Data\\QGen\\SortBuilder.cs:line 176\r\n at Marr.Data.QGen.SortBuilder`1.GetEnumerator() in m:\\BuildAgent\\work\\6c3239faf2b92630\\src\\Marr.Data\\QGen\\SortBuilder.cs:line 247\r\n at System.Linq.Enumerable.SingleOrDefault[TSource](IEnumerable`1 source)\r\n at NzbDrone.Core.Authentication.UserRepository.FindUser(String username) in m:\\BuildAgent\\work\\6c3239faf2b92630\\src\\NzbDrone.Core\\Authentication\\UserRepository.cs:line 0\r\n at NzbDrone.Core.Authentication.UserService.FindUser(String username, String password) in m:\\BuildAgent\\work\\6c3239faf2b92630\\src\\NzbDrone.Core\\Authentication\\UserService.cs:line 76\r\n at NzbDrone.Api.Authentication.AuthenticationService.Validate(String username, String password) in m:\\BuildAgent\\work\\6c3239faf2b92630\\src\\NzbDrone.Api\\Authentication\\AuthenticationService.cs:line 43\r\n at Nancy.Authentication.Basic.BasicAuthentication.RetrieveCredentials(NancyContext context, BasicAuthenticationConfiguration configuration)\r\n at Nancy.Authentication.Basic.BasicAuthentication.<>c__DisplayClass1.<GetCredentialRetrievalHook>b__0(NancyContext context)\r\n at Nancy.BeforePipeline.<>c__DisplayClass4.<Wrap>b__3(NancyContext ctx, CancellationToken ct)"
Killed Sonarr process through task manager. The only unusual occurrence was that IE reported blocked content on the Calendar.
On restart a message box pops saying the following before the process terminates
SQLiteException: disk I/O error
disk I/O error
