Directory Issue With Two Similar Shows
I tried adding both Dragons’ Den and Dragons’ Den (CA). They get a URL of “dragons-den” and “dragons-den-ca”. However, when I add the 2nd one, I get a 404 error when I try to navigate there. It doesn’t matter which order I do it, the first one works, but the second one will always give that error. Any ideas?
Both load correctly for me.
Anything in the log files?
Try restarting Sonarr?
I was finally able to check this again, and this time they both showed up. I didn’t do anything to fix it though.
Thanks for the tips though…
