Develop 2.0.0.2475 - torrent download sent to client, nothing happens [fixed, tracker issue]
Edit: Ignore, issue with tracker.
I just confirmed it, someone uploaded the download as S01E09, while it’s really S01E08. It was renamed at “search results from kickass” level, but obviously the folder/file inside the torrent are still called S01E09. So sonarr grabs it because I’m missing S01E08, but then ignores it to import because it sees “hey, transmission has S01E09, I don’t want that”.
For those interested, it’s The Knick S01E08 on kickass torrents.
Historical post, worthless now…
"I upgraded to 2.0.0.2475 in develop.
I noticed first that all the options to specify a a retry count etc are gone. All I have left are the yes/no toggles for completed download handing (enable, remove) and failed download handing (redownload, remove). All 4 are set to “on” (as it was before).
Now when a torrent is sent from sonarr to transmission, it doesn’t show up in the activity queue, and when it’s completed in transmission, it just sits there. Sonarr is not picking it up.
Here’s a pastebin with debug logs. I manually sent a torrent from sonarr to transmission for testing purposes. I tried to rule out as many things as possible, so the download is also a match for my quality profile.
http://pastebin.com/c1kKWuKS
  • click Manual Search, sonarr parses results, I select the one I want
  • 14-12-20 07:14:55.9|Info|DownloadService|Report sent to download client.
  • the torrent completed at around 07:25 in transmission
  • …nothing
Ummm what else? This was working fine before upgrading, sonarr and transmission are on the same machine, they can see each other, …"
