I recently added a new show, Deutschland 83 (TVDB show number: 294801) to my library and have been waiting for Sonarr to pick it up. Whilst the first two episodes are available on my indexer (filenamed as Deutschland.83.S01E02.Brave.Guy.720p.WEB-DL.DD5.1.H.264-NTb), it is not being picked up with a manual search in Sonarr.
Any suggestions as to why this could be the case?
What do debug logs show for that manual search? What rejection reason is listed for the manual search?
I can’t see any rejection reason, it just doesn’t pick them up.
Insert from the log files is below:
15-7-3 16:10:44.8|Info|NzbSearchService|Searching 3 indexers for [Deutschland 83 : S01E03]
15-7-3 16:10:48.8|Info|DownloadDecisionMaker|No results found
15-7-3 16:13:27.2|Info|NzbSearchService|Searching 3 indexers for [Deutschland 83 : S01E01]
15-7-3 16:13:32.0|Info|DownloadDecisionMaker|No results found
You need to turn on debug logging first.
My bad, here you go:
15-7-4 08:20:31.9|Info|NzbSearchService|Searching 3 indexers for [Deutschland 83 : S01E01]
15-7-4 08:20:31.9|Debug|Newznab|Downloading Feed https://api.nzb.su/api?t=tvsearch&cat=5030,5040&extended=1&apikey= &offset=0&limit=100&rid=44640&season=1&ep=1
15-7-4 08:20:31.9|Debug|Newznab|Downloading Feed https://api.nzbgeek.info/api?t=tvsearch&cat=5030,5040&extended=1&apikey= &offset=0&limit=100&rid=44640&season=1&ep=1
15-7-4 08:20:31.9|Debug|Newznab|Downloading Feed https://www.usenet-crawler.com/api?t=tvsearch&cat=5030,5040&extended=1&apikey= &offset=0&limit=100&rid=44640&season=1&ep=1
15-7-4 08:20:37.7|Debug|NzbSearchService|Total of 0 reports were found for [Deutschland 83 : S01E01] from 3 indexers
15-7-4 08:20:37.7|Info|DownloadDecisionMaker|No results found
Most likely the indexer not associating the series title with the tvrageid.
TTT
July 5, 2015, 10:41am
7
More than likely they are in the foreign newznab category on your indexers (They mostly are on mine).
You can add category 5020 to your indexer settings in Sonarr and they will be picked up.
Yep, that was it!
Thanks for the advice TTT.
system
Closed
September 3, 2015, 11:18am
9
