I use a separate computer with Plex on it to watch and host all of my media. I have Sonarr and torrenting set up on a computer different to that. Is there a way to detect the media on the other computer as downloaded and ‘obtained’ in sonarr?
Sonarr will need access to the files to see that they are available, by a network share in your case.
In what way would I be able to set that up? Would I just need to make the files available for sharing to my ‘homegroup’ for example or is there another way? I’m on windows 7 if that helps any.
I’m not sure if a homegroup will work or not. Sonarr will need to see the share via a path such as: \\server\share
Sorry, could you expand on what you mean a bit? \server\share for example, I have no idea what that means. Sorry for the hassle.
Google on how to setup a share in Windows, but since you’re getting the media to the remote machine already you can probably do the same thing.
