Deluge torrent client problems
Hi all,
First of all THANK YOU for torrent support. It’s working great for me. However, I’m using black hole at the moment as I can’t get Deluge to work.
I’ve changed the interface port on Deluge from 8112 to 7004 and I have a blank password. Whenever I try to set it up in NZBDrone I get an “Authentication Failed” message next to the password box. I’ve tried setting a password but that doesn’t help.
Has anyone got any idea what could be wrong?
Thanks,
Max
So 7004 is the webui port?
Please note the password is the one specified in the webui.
What password did you use? by default, deluge is configured with ‘deluge’ as password.
I made the mistake of clicking apply when trying to change the password in the webui…You have to click the change button underneath the password change box, if that is your problem :smile: .
Oops, I didn’t see the post was 5d old.
