I’ve been trying to investigate why completed downloads are not removed once they are moved over by Sonarr, and when looking in the debug logs, I notice that I have a lot of Deluge errors. (I did have it configured when I had a little play around with it, but I removed it again).
How do I get Sonarr to realise that I no longer use it?
Error message :-
`15-12-3 11:37:36.9|Warn|DownloadMonitoringService|Unable to retrieve queue and history items from Deluge
System.Net.WebException: Unable to connect to the remote server —> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 192.168.1.15:38081
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at NzbDrone.Core.Rest.RestSharpExtensions.ValidateResponse(IRestResponse response, IRestClient restClient) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Rest\RestSharpExtensions.cs:line 22
at NzbDrone.Core.Rest.RestSharpExtensions.Read[T](IRestResponse restResponse, IRestClient restClient) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Rest\RestSharpExtensions.cs:line 60
at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.ProcessRequest[TResult](IRestClient client, String action, Object[] arguments) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 225
at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.AuthenticateClient(IRestClient restClient) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 265
at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.BuildClient(DelugeSettings settings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 251
at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.ProcessRequest[TResult](DelugeSettings settings, String action, Object[] arguments) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 162
at NzbDrone.Core.Download.Clients.Deluge.DelugeProxy.GetTorrentsByLabel(String label, DelugeSettings settings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\DelugeProxy.cs:line 79
at NzbDrone.Core.Download.Clients.Deluge.Deluge.GetItems() in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Deluge\Deluge.cs:line 94
at NzbDrone.Core.Download.TrackedDownloads.DownloadMonitoringService.ProcessClientDownloads(IDownloadClient downloadClient) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\TrackedDownloads\DownloadMonitoringService.cs:line 86
