Hi there - I am also having the same problem and although I understand the above posts, I’m still not sure what I am supposed to put in the URL base setting. Is it my seedbox username?
Looks like you’re using the wrong port and missing part of the UrlBase: https://www.feralhosting.com/faq/view?question=146 Relative Path in that article appears to correspond to Sonarr’s UrlBase field.
I left the port blank and the base url to /username/deluge/
Here’s what’s happening in the log:
15-8-7 22:40:54.2|Fatal|NzbDroneErrorPipeline|Request Failed
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at System.String.System.IConvertible.ToInt32(IFormatProvider provider)
at System.Convert.ToInt32(Object value)
at NzbDrone.Api.ClientSchema.SchemaBuilder.ReadFormSchema(List`1 fields, Type targetType, Object defaults) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\ClientSchema\SchemaBuilder.cs:line 80
at NzbDrone.Api.ProviderModuleBase`3.GetDefinition(TProviderResource providerResource, Boolean includeWarnings) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\ProviderModuleBase.cs:line 113
at NzbDrone.Api.ProviderModuleBase`3.CreateProvider(TProviderResource providerResource) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\ProviderModuleBase.cs:line 77
at NzbDrone.Api.REST.RestModule`1.<set_CreateResource>b__f(Object options) in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\REST\RestModule.cs:line 155
at CallSite.Target(Closure , CallSite , Func`2 , Object )
at Nancy.Routing.Route.<>c__DisplayClass4.<Wrap>b__3(Object parameters, CancellationToken context)
80!! That was it! Thank you very much!! Could you explain why that is - it’s not mentioned in any set-up guides I found.
For posterity’s sake and for anyone who ever comes across this in the future looking for the complete answer, the settings you need are:
Host: servername.feralhosting.com
Port: 80 (if SSL off)
URL base: /username/deluge/
Password: password given by your seedbox (and not the one from setting up the deluge thin-client)
Either the author thought it was irrelevant or they aren’t using feral would be my guess. Unfortunately people will often find a solution and not report what it was, so much appreciated that you included it.
