I’m having issues connecting with deluge. It all worked fine until I added a base url to deluge in order to access it from behind a reverse proxy. For instance, localhost:8112/dl/ is now the local web interface instead of localhost:8112.
Is there any way to specify the base url to nzbDrone so it can talk to it again?
Ah, ok. Maybe I should add this as a feature request? I know a lot of people operate behind a reverse proxy. I may do a temporary hack to the code to fix my problem and hopefully it’ll be a feature at some point in the future.
