Hey,
So I am trying to connect Sonarr through a Deluge Daemon running on a seedbox from my QNAP NAS. I have this working in couchpotato and want to get this working with Sonarr. I need to enter a username to connect though and I don’t need to have a field for this. Is there any way to configure this or does the Daemon not work with Snoarr?
Show advanced settings and you will be able to alter the urlbase.
Does this still depend on the webUI or can that base the information to the daemon to. I have never user a urlbase to pass my username to deluge. Any tips?
Thanks
Sonarr connects to the WebAPI, but it looks like CP connects to the RPC API. The WebAPI doesn’t have a username that I’ve seen.
The URL Base controls the path that you connect to on the server into order to hit your deluge instance, in the case of seed boxes its part of the URL.
From what I have read Sonarr can only use the WebAPI. Is there any plans to allow RPC API connection?
Possibly down the road, but not something we’re looking at, at the moment.
